Order Ford 8N Parts Online
What's the trick to getting the starter out of a '52 8N?
Applegeek
05-04-2008 22:18:15
Dang it...I had the tractor running fine last week, until the starter decided to have its brushes wear out.
I removed the solenoid, and removed the two bolts holding the starter on. Now the rotor + Bendix assembly looks like its captured by the flywheel. I know this had to to be assembled, but there looks to be a washer on the rear end of the Bendix that won"t clear the flywheel...or at least I"m not getting the angle right.
Is the Bendix gear + over-run assembly supposed to all be on the starter rotor shaft, or is this supposed to separate? Or do I not have quite the right angle to slip everything out yet?
Applegeek
05-05-2008 22:01:18
 Re: What's the trick to getting the starter out of a '52 8N? in reply to Applegeek, 05-04-2008 22:18:15
Got it out...It actually wasn't brushes, but the coil connections to the main power terminal were loose. I soldered them on, cleaned up the armature contacts, put everything back together, and its running fine again.
And, yes, a good deal of holding your tounge just right helps ease the starter + Bendix back over the flywheel. I used a few strips of strapping tape to hold the motor together, then once the starter was in position I slipped out the tape and inserted the long bolts.
Thanks, guys!!
ZANE
05-05-2008 18:08:54
If the starter has the newer type starter drive gear assembly (Bendix) It may be necessary to pull start the engine so the Bendix can be unlatched before the starter will come out of the clutch housing.
If you do have a later model Bendix do not spin the starter while it is out of the tractor trying to "test" it. Doing this will make it impossible for the Bendix to be inserted into the clutch housing.
Zane
Duffy
05-05-2008 09:07:48
Boy you leave this board for a while and things sure change. IN MY DAY, the reply would have to remind the importance of holding your mouth just right.
But I geuss that part has been outsourced.
Bruce (VA)
05-05-2008 05:07:16
To remove the starter, unscrew the bolts out of the block & put a nut on one of them. Otherwise, the starter comes apart. Not fatal, but not fun either. Then, loosen the two bolts holding the oil filter canister to the block, remove the dipstick, and keep the starter close to the block while pushing the front of it down and lifting the back up. Sometimes you have to remove the drain petcock as well.The bendix is behind the flywheel; your job is to get it over the flywheel.
To install the starter, keep it close to the block while pulling the front of it up and pushing the bendix back into the hole. The bendix has to go behind the flywheel; your job is to get it over the flywheel. Grinding out an egg shape at the 2 o'clock position before you put it back will make your life easier.
Lastly, while the starter is off, polish the block & starter mating surfaces w/ sandpaper to insure a good electrical ground between the two, and clean the mating surfaces where the starter's "belly" meets the aluminum endbell. The starter's ground circuit is through that "joint" as well was through the starter endbell-to-flywheel housing joint.
Bill(NC)
05-05-2008 04:08:58
I removed the drain, per this forum, and it seemed to give just enough room to get the starter out with no trouble.
Dell (WA)
05-04-2008 23:16:24
Applegeek..... ..ya ain't holdin' yer tongue just right (grin)
You are right, you haffta lift yer back driving Bendix UP'n'OVER the flywheel starter ring. This is accomplished by pointing the starter DOWN'n'IN towards the block drain. Some people gitt so frustrated they take out the block drain. It usually don't drain 'cuz its all crudded up. Some unbolt the oilfilter and letter dangle. Some actually GRIND about 1/4" relief arch at about 1-2o'clock AFTER they gitt that SOB outta the hole. It don't hurt 'nuttin' and is covered up with the starter after re-installation.
tip: NUT yer 8" bolts with 5/16 NC nuts so starter don't cumm'appart while yer jigglin' it over the ring.
TIP#2: seriously consider replacing the starter Bendix with the NEW clutch style bendix. $30 (cheap)..... ..the twisted tongued Dell (say that 3-times fast)
Applegeek
05-05-2008 06:30:01
 Re: What's the trick to getting the starter out of a '52 8N? in reply to Dell (WA), 05-04-2008 23:16:24
Thanks, guys!...I just wanted to make sure I wasn't missing something easier. I'll go tinker on it in a bit.
