Order Ford 8N Parts Online
Ford 8N Disconnecting the Fuel Line
Ray Goodson
05-08-2008 19:52:00
Does it require a special tool? I tried using a pair of plyers and it won't budge. I think the fuel line must be clogged because the engine will start but shuts down after a minute or so.
Any ideas?
old
05-08-2008 21:34:00
 Re: Ford 8N Disconnecting the Fuel Line in reply to Ray Goodson, 05-08-2008 19:52:00
Thats a case of the right tool for the right job. Plyers are not and never will be the right tool. On most you need a 7/16 wrench to do that. Plyers are good with fence etc but thats it
gahorN
05-09-2008 01:42:57
 Re: Ford 8N Disconnecting the Fuel Line in reply to old, 05-08-2008 21:34:00
Loosen the fuel cap and see if it'll keep running. (Plugged vent... so drill a 1/8" hole thru the center of the fuel cap.... away from the fuel tank.)
Clean the gascolator screen.
Pete Cowart
05-08-2008 20:15:56
Sears makes a tool called a "line wrench", brake line, fuel line etc. They can probably be bought individually or as a kit.
Pete
soundguy
05-08-2008 20:06:17
While a set of gas pliers should remove the fuel line nuts no problem, you will really chew them up. a WRENCH is the proper tool to use.
Nothing special about them.
Don't guess about running out of fuel.. check it. Pull the bowl drain on the carb and see if the carb bowl has fuel in it when she stalls.
soundguy
