12V conversion using Delco 12si alternator?
tesmith66
05-09-2008 03:57:09
I am putting lights on my 2N and have a 12V 25 gallon sprayer tank I want to use, therefore a 12V conversion is in order. I have 2 Delco 12Si alternators (the mid 80's big brother to the 10Si) laying around and was wondering if the wiring for those would be the same? Will the slightly larger case size be a problem? Should I just get a 10Si?
Thanks!
tesmith66
05-12-2008 03:32:59
 Re: 12V conversion using Delco 12si alternator? in reply to tesmith66, 05-09-2008 03:57:09
I thought about that, but I already have all of the conversion stuff laying around, and I'm in the process of putting the tractor back together so...
Besides, I want to run a full set of lights, and I hear the 6 volt ones aren't very bright.
36 coupe
05-10-2008 04:57:54
I put a 12v battery on my sprayer.A full charge lasts a long time.Save the conversion money for spray materials.
tesmith66
05-09-2008 04:07:31
Me again :lol:
Just found this link that describes all of the differences between the two. It appears that it will work just fine in the "traditional" way.
Thanks for watching me have this little conversation with myself. :wink:
LeeMo
05-09-2008 08:21:18
 Re: 12V conversion using Delco 12si alternator? in reply to tesmith66, 05-09-2008 04:07:31
LMAO!! Talked yourself right through that one, didn't ya!! Glad you figured it all out.
tesmith66
05-09-2008 08:27:45
 Re: 12V conversion using Delco 12si alternator? in reply to LeeMo, 05-09-2008 08:21:18
LeeMo said: (quoted from post at 08:21:18 05/09/08) LMAO!! Talked yourself right through that one, didn't ya!! Glad you figured it all out.
Okay, now I'm hearing voices that don't belong to me...
LeeMo
05-09-2008 09:59:48
 Re: 12V conversion using Delco 12si alternator? in reply to tesmith66, 05-09-2008 08:27:45
Sorry, I didn't mean to interrupt..... .....LMAO!
tesmith66
05-09-2008 03:59:21
Just found out the cases are the same size, so that question has been answered.
