nondem..... ..proper battery size fer 12v conversion is either #22 or #35. Interestingly enuff, the OEM 6v battery is listed as 13-plates, not even by voltage or now standardized battery size spec-1A. And since you have a 12v genny, you can install yer battery either positive or negative ground. Electrons don't care but yer square can voltage regulator does, so whether you negative or positive ground, REPOLARIZE!!! anyways. Ask yer genny guy how to do it with yer "weird" set-up 'cuz it could be one of several different ways. I suspect it ain't the same as OEM 8N squarecan V/R, so I ain't gonnna tell you how. As fer yer wiring, COLOR is yer friend. Follow yer colored wires. Since YELLOW goes thru yer loop ammeter, it is yer BATTERY charge wire and BATT terminal on yer squarecan V/R. Since BLACK is connected to yer squarecan V/R baseplate as GROUND. Now all ya haffta to do is follow the white and red wires to yer 12v genny. Generally the HEAVY RED wire is yer genny ARMATURE output. And that leaves the WHITE as yer FIELD. You should also look CLOSELY at yer squarecan terminals 'cuz surprizingly enuff, they are usually LABELED too. Isn't that amazing??? Always use proper terminal lugs and stranded wire ..... ..respectfully, Dell
