Order Ford 8N Parts Online
Operation 8N: "V" for Victory!
Ed S. (IL)
05-10-2008 08:41:37
Praise the Lord, the pin is OUT! I went out to check on it this morning, and pumped the press jack a few more times until the punch I was using as a drift started to bow a little (yikes!), and then decided to hit it with some more heat. I put the flame on it for maybe 15 seconds, and there was a loud report (sounded like a rifle shot, and made me jump!), and the pin had finally broken loose. I had to press it all the way out, with the pin making a pop every four or five pumps on the jack.
third party image
es
JMOR
05-10-2008 11:15:54
 Re: Operation 8N: V for Victory! in reply to Ed S. (IL), 05-10-2008 08:41:37
Rust is strong!
But fire is stronger.
Dell (WA)
05-10-2008 11:03:41
Ed..... ...I'll bett'cha you install yer NEW pin with "anti-seize", eh? Clean-up inside yer axlepin hole with DRILL of appropriate diameter (rent one?) I know BIG DRILLS are expensive. or reamer. You can carry yer axle into a machineshop for drill and ream job. $10/hole. and treat the hole with rust killer of somekind that contains "phosphoric acid"..... ..Dell
GB in MT.
05-10-2008 09:05:53
 Re: Operation 8N: "V" for Victory! in reply to Ed S. (IL), 05-10-2008 08:41:37
Good news Ed;
Now see, you should have held your mouth that way two days ago, and ya would be two days ahead of time!!! :lol:
Great!!! I'm sure glad that's over!!!! Now, put it back in and see if ya can do it again! :lol:
Gary :)
