coil
ok bill
05-11-2008 10:55:20
on a 6 volt pos ground what side of lead wire is to the dis from the coil plus or neg,trying to get it started i get fire to the points but no fire to plugs. thanks bill.
Bruce (VA)
05-11-2008 13:36:45
 Re: coil in reply to ok bill, 05-11-2008 10:55:20
Like Old sez, positive ground, plus to points. (tip # 33 at the link below) But, even if you had it backwards, it shouldn't result in a 'no spark' condition. Is it a front or side distributor?
OK BILL
05-11-2008 13:57:56
 to bruce in reply to Bruce (VA), 05-11-2008 13:36:45
bruce it is a side mount 1950 8n,i have fire at coil post both batt and neg but still no fire to plugs, i also have fire to points and also have cheked gap on points i can arc fire from one side of points to the other with screw driver but no fire to plugs also check cap for cracks and bug.
Bruce (VA)
05-11-2008 14:06:15
 Re: to bruce in reply to OK BILL, 05-11-2008 13:57:56
The fact that it sparks doesn't tell you how much voltage you have. You really need a meter.
Verify the gap on the points at .025. Then, run a new clean dollar bill through them. New points sometimes have a residue & old points can corrode, or get grease from the distributor cam on them. Or, you could have used a dirty feeler gauge. (I always spray mine off w/ contact cleaner.) Make sure you have voltage across the points, as in past the insulator on the side of the distributor. That insulator is the number 1 failure point on a sidemount. If you just replaced the rotor & lost spark, put the old one back in. Check continuity on the secondary coil wire. Make sure it is firmly seated in both the cap & the coil. In fact, replace it temporarily w/ a plug wire. Post back w/ results; I'll be interested in what the problem was.
old
05-11-2008 11:32:21
What ever your ground is is also the side of the coil that goes to the distributor. So if + ground the + side of the coil goes to the distributor
OK BILL
05-11-2008 12:01:50
 Re: coil in reply to old, 05-11-2008 11:32:21
thank you old for your input. bill
