square can reg
ok bill
05-11-2008 17:58:36
thanks to old and bruce i have my 8n sidemount runing again but i would like help with my 6 volt regulator it is orginal and hasent worked sence i got it,well the needle jumps back and fourth when it runs it is the old loop type,took off the regulator so i could take out the old riverts and am going to reinstall it to see if the points are working right and would like to know if there is something i should look for other than that?
JMOR
05-13-2008 06:33:44
 Re: square can reg/soundguy in reply to StormCloud601, 05-11-2008 17:58:36
OK BILL said: (quoted from post at 21:58:07 05/11/08) soundguy what are the specs for mica higth? is it 3/32 depth?
1/32 "
soundguy
05-11-2008 18:29:04
 Re: square can reg in reply to ok bill, 05-11-2008 17:58:36
Bouncy readings can also mean worn brushes and tall mica in the genny.
soundguy
OK BILL
05-11-2008 18:58:07
 Re: square can reg/soundguy in reply to soundguy, 05-11-2008 18:29:04
soundguy
05-13-2008 04:57:47
 Re: square can reg/soundguy in reply to OK BILL, 05-11-2008 18:58:07
Can't quote you a spec.. but i undercut them a 'hair'.. that way the brushes don't hang.. etc.
soundguy
JMOR
05-11-2008 18:23:05
 Re: square can reg in reply to Too Tall, 05-11-2008 17:58:36
ok bill said: (quoted from post at 20:58:36 05/11/08) thanks to old and bruce i have my 8n sidemount runing again but i would like help with my 6 volt regulator it is orginal and hasent worked sence i got it,well the needle jumps back and fourth when it runs it is the old loop type,took off the regulator so i could take out the old riverts and am going to reinstall it to see if the points are working right and would like to know if there is something i should look for other than that?
You said ammeter jumps back & forth..... .sounds like it may be charging? Does it keep the battery charged?
As far as looking, stuck contacts, broken springs, burnt wires, etc. There is a resistor on the back...examine for cracks & you can measure it. My original 8N-10505B (Auto-Lite, VAZ-4001A, ser # 3-E007176) has the value, "20" (ohms) stamped in the resistor. I do not recommend disconnecting this type of resistor, as it may break like crock or ceramic.
third party image
Dell (WA)
05-11-2008 18:11:11
Bill..... I'm assuming this is an "intelectual exercise"? 'cuz as a general rule, mechanical relay failures are non-repairable. Why? 'cuz relay armature pivot points are NOT jeweled bearings, they're plain soft metal and subject to non-repairable wear. While you can sometime "polish" the contact points with fine ladies sandpaper fingernail files, that generally leads to shortened life and 'nutter' re-file. Naturally, a continuity check is du-riggur on all coils and anti-overcurrent resistors..... ...Dell
