Order Ford 8N Parts Online
Operation 8N: bent lift linkage arm - a problem?
Ed S. (IL)
05-13-2008 20:27:04
Okay, I need opinions here... The long thin arm that runs from the position control lever down to the pump valves appears to have a slight bend in it. Also, the rear differential casting had a bulge in it at the rear of the opening where the lift cylinder cover sits. Seems like I read something here that that's a symptom of the lift getting bumped up against the stop or something.
third party image
So the question is: do I need to straighten the linkage arm, or is it supposed to be like that? I already ground the bulge in the casting down flat, BTW.
Thanks for your input,
es
tatanka
05-14-2008 07:45:43
 Re: Operation 8N: bent lift linkage arm - a problem? in reply to Ed S. (IL), 05-13-2008 20:27:04
What causes the arm to bend like that?
Dell (WA)
05-14-2008 07:55:06
 Re: Operation 8N: bent lift linkage arm - a problem? in reply to tatanka, 05-14-2008 07:45:43
Tatanka..... ..thats the hy-trol sword. NOT supposed to be bent. It controls the hydraulic pump valve for uppsies'n'downsies. It usually gitts bent from carrying a heavy implement in air and driving FAST over rough bouncy ground. Yeah, it can be straightened and should be..... ...Dell
john fl
05-14-2008 04:51:49
Ed,
I have an extra one if you can't get that one to work,
john
dlplost
05-14-2008 00:44:17
third party image
as long as you can adjust it to work it's not a problem. To straighten it you just put it on a block of wood and hammer on it, it's soft and will bend back easily.
Now, what you got there in your picture looks good, here's a bent one... Yes we straightened it out and it works perfectly. We also bought Zane's adjustment jig, and got it adjusted correct the very first try.
