stabilizer bar installation
4-t-niner
05-14-2008 12:07:25
I purchased the stabilizer bar kit from this site. How do I install them?
Dunk
05-16-2008 19:02:58
 Re: stabilizer bar installation in reply to 4-t-niner, 05-14-2008 12:07:25
The fender bolts were originally fine thread.
jr27red
05-16-2008 17:55:19
the stabilizer bar pins need to be inline with the tractors lift arms or it will bend them.
hoz. and for&rev
jon
05-14-2008 14:18:48
 Re: stabilizer bar installation in reply to Tom N MS, 05-14-2008 12:07:25
GB in MT. said: (quoted from post at 16:48:46 05/14/08)
Holy Moly; "Hermie's Butt", is on ebay again!!!! :lol:
Gary 8)
You should get royalties!
Can I have his autograph?? :lol:
jon
05-14-2008 13:24:01
Then go getcha a set of these so you don't tear em off.
GB in MT.
05-14-2008 13:48:46
 Re: stabilizer bar installation in reply to jon, 05-14-2008 13:24:01
Gary 8)
soundguy
05-14-2008 12:12:51
They mount using the fender bolts.. mount the flange toward the center of the tractor. Ther ewill be a nubby pin in each bracket. Put that pin in the hole that will let it be on the same plane as the 3pt lift arm pin. then put the stab brackets on a drawbar and lift by hand to make sure there is no binding.
occasionally some universal sets have slots instead of holes.. in this case.. hand tighten the nuts, lift the lift by hand to let the brackets find their happy place.. then snug the nuts and nubs down.
soundguy
36 coupe
05-15-2008 04:16:52
 Re: stabilizer bar installation in reply to soundguy, 05-14-2008 12:12:51
Ive had to use longer fender bolts on some tractors.
soundguy
05-15-2008 05:56:19
 Re: stabilizer bar installation in reply to 36 coupe, 05-15-2008 04:16:52
Yep.. Ditto that. longer bolts are usually needed if they havn't already been changed out.
soundguy
