Two row sweet corn
9nRowcropper
05-15-2008 07:13:24
Hey guys, My uncle and I rebuilt a Ford 9n over the winter. I just plowed and disked 4 acres to be planted into corn with a dearborn two bottom plow. I just got myself a planter. Any tips on speed or row spacing.
Timski
05-15-2008 17:39:29
 Re: Two row sweet corn in reply to 9nRowcropper, 05-15-2008 07:13:24
I just planted 3 acres with a ford 9n with a blackhawk 2 row corn planter at 40 inch spacing. I ran in 2nd gear 1/2 to 3/4 throttle. My planter has 3 different settings of seed spacing, I used the closest one.
Ed S. (IL)
05-15-2008 08:21:29
I plant at 36" spacing, which fits my cultivator. I have to flip the wheels around on the N to cultivate (wide spacing), which works fine (just have to remember to swap sides on the rears so the bars are facing the right direction).
I have an old JD four-row planter, but it's rusted up and missing chains. Drug it through the field to make furrows this year, and worked okay for that. I think I can get it loosened up and maybe $50 of chains will get'er goin' again.
I would think slow 'N steady would be the right speed for planting.
es
Den N Ms
05-15-2008 07:53:26
9nRowcropper,Most of the row crops planted back in the day were 38" or 40 " rows,wheels set out wide.That would depend on your planter row spacing,and if you are going to use a cultivator on it needs to be set the same as the planter.Planting speed with your 9N 2nd gear 1/2 throttle would work.
