Order Ford 8N Parts Online
Operation 8N: Drag Link Question
Ed S. (IL)
05-15-2008 19:06:52
Okay, so I ordered new front and rear tie rod ends, and the fronts arrived today. Looked at my old rods, and only one end is threaded where I can remove the old end to replace it. The other end has the rod end integral to the rod. Anyone seen one like this before?
Looks like I'll need to order new tie rod tubes, too...
es
Dunk
05-16-2008 08:22:47
 Re: Operation 8N: Drag Link Question in reply to Dell (WA), 05-15-2008 19:06:52
don b said: (quoted from post at 11:31:57 05/16/08) Dunk....there is a chart at the top of page 43 of the MPC,that explains the different drag link parts and what parts are needed for diff tractors and steering boxes.Would you be so kind as to copy and post it here on the board?It would make it a lot easier to explain what parts are needed to get the correct steering on our tractors.While it may be simple to you and me,others may need to see it in writing or pictures.Thanks for your help. don b
Gary took care of that...
Link
Ed S. (IL)
05-16-2008 05:30:46
 Re: Operation 8N: Drag Link Question in reply to Ed S. (IL), 05-15-2008 19:06:52
36, that answered my question. I went ahead and ordered new tubes from the YT store - don't have a big welder, and I can just bolt up the tubes and ends and be done with it.
thanks!
es
36 coupe
05-16-2008 04:41:38
New long type rear ties rod ends are NA.But parts from NH dealer would cost 125.00.When a rear tie rod end was shot on a friends 8n on the left side,I measured the right tie rod tube on my 640.Same length.Called wengers and got a nice used tie rod for 30.00 shipping included.It was complete with good ends.
36 coupe
05-17-2008 02:04:55
 Re: Operation 8N: Drag Link Question in reply to don b, 05-16-2008 07:38:17
Cant find the original long rear tie rod ends.Ford tie rods have been a problem for years.Carpenter may be selling the long ends now.In any case a bad left tie rod on an 8N can be fixed fast by using the right tie rod from a 640.I favor used USA parts over new import parts.
don b
05-17-2008 06:28:50
 Re: Operation 8N: Drag Link Question in reply to 36 coupe, 05-17-2008 02:04:55
36 coupe.....Carpenter is making the complete draglinks,but he won't sell just the rear tie rods.You have to buy the complete draglink. don b
Dunk
05-15-2008 19:57:43
I need to do that too, I have the same issues. (done researched it)
Right now mine still work, and that is what I want, a werker...
So for now that is way back on the back burner.
souNdguy
05-15-2008 19:55:05
third party image
You can always cut the ole one off, and slip the new one in and weld it ( it was solid after all ).. or split the tube with a grinder and thread the ID and then use a HD pipe clamp on it.
I made a draglink tube for my 951 in a similar fashion.. use thick wall conduit and some welding.. works fine.. even with a laoder attached and no power steering.
soundguy
Ed S. (IL)
05-15-2008 19:29:24
The shop manual picture shows separate ends with a tube in the middle - definitely NOT what I have on my N. A new middle section should set me up (since I already ordered new ends), so out comes the CC again!
es
don b
05-16-2008 07:31:57
 Re: Operation 8N: Drag Link Question in reply to Dunk, 05-15-2008 19:15:34
