Order Ford 8N Parts Online
Wont start, 1949 8n
Peter
06-13-1999 04:41:54
I was mowing and stalled in high grass. Couldnt restart. I get ratcheting sound from starter when trying to start. Sound comes and goes if I tap lightly with hammer on starter. I tied to jump start with same result. engine not turning over.sometimes slow ratcheting sound, sometimes nothing as i push start button.HELPand Thanks in advance for helping this tinhorn.
Peter
06-13-1999 08:30:14
 Re: wont start, 1949 8n in reply to Peter, 06-13-1999 04:41:54
thanks steve it is a clicking sound. Ill go try out your suggestion. Is it ok to Jump start 6volts with 12vots?
RWK in WI
06-13-1999 09:28:43
 Re: Re: wont start, 1949 8n in reply to Peter, 06-13-1999 08:30:14
You can jump 6v from 12v if you do it correctly and disconect quickly.
I am guessing that the tractor is positive ground. If so procede as follows.
!. Turn ignition of tractor on. Donor vehicle offf.
2. Connnect Nevative 12V to battery connection at starter.
3. Connect 12v Posttive to tractor frame or engine away from carb.
4. press starter. 5. disconnedt cables as soon as engine starts.
Some would say you need to wear eye / face protection any time you work near batteries.
Be Safe.
RWK in WI
06-13-1999 09:07:55
Be Safe.
Steve (IA)
06-13-1999 06:23:21
If the sound might be a click,click,click instead of a ratcheting noise, I've solved similar problem by cleaning battery terminals and cable ends and the tractor ends of these cables. If it is a bad connection, you may have to recharge/jumpstart as you may have a discharged battery due to poor connections. good luck
Wayne
06-13-1999 05:24:40
Try using a jumper wire (heavy gauge)and jump the two large terminal on the solinod. Sometimes the push start button does not make good contact.
