pto info
ray whitaker
05-18-2008 19:02:25
i have a 1952 ford 8n and i need some infomation. dose the pto have to be engage for the 3pt. to work? also what is the lever position or draft for?
KCM
05-20-2008 09:56:52
 Re: pto info in reply to ray whitaker, 05-18-2008 19:02:25
That little lever under the seat can be used to bypass the draft control. When up, the implement will stay at the same height in relation to the tractor. When down, the draft control becomes active and the implement, such as a plow or cultivator, will stay at the same ground depth independent of the tractor.
Tom N MS
05-18-2008 19:12:23
Yes, PTO must be engaged for the lift to work. Lever under seat basically up for hogging and other above the ground work, down for plowing.
