Order Ford 9N Parts Online
9N charging problem help!!!
Paul in NY
05-18-2008 19:45:55
I have a 9N that would not charge. The trator was changed from a 1 wire generator to a 3 wire and the wiring harness was all chopped up. I installed an 8N front mount distributer harness had the generator rebuilt and put an 8n front mount distributer style regulator. Cleaned all connections. jumped from battery to armiture on the regulater and it still won't charge. I'm stumped.
JMOR
05-18-2008 21:57:48
 Re: 9N charging problem help!!! in reply to Denny (WI), 05-18-2008 19:45:55
Paul in NY said: (quoted from post at 00:51:36 05/19/08) Thanks guys.
I will re check my wiring against the diagram. Then I'll try grounding the field. Should it go to charge after I ground the field. All else has been done that you guys suggested. I wont be able to work on it till the weekend but I'll get back to you and let you know how I made out. Again thanks for you help.
Since it was changed to "a 3 wire generator", that means we really don't know what generator you have , do we?
Just in case you have a type-B instead of a type-A, you might want to determine this.
Paul in NY
05-18-2008 21:51:36
 Re: 9N charging problem help!!! in reply to Paul in NY, 05-18-2008 19:45:55
Thanks guys.
GB in MT.
05-18-2008 20:36:11
Paul;
That is exactly the way my 2N is wired.
First ?.....When you did these changes did you make up a wiring diagram of the changes?
Second ?..... Are you saying the 3 wire genny you installed has connections for AMP....Field....and Grnd. ?
Third ? When you installed all of this did you POLARIZE the charging system at the Regulator.
Forth thing to do.....If the answer is yes to the three ?'s above, check your wiring against my wiring diagram. If you are still having NO charge.
Make sure the Grounding for the Regulator is nice and shiny.
Then repolarize the system, as in the polarizing pic. shown here.
My wiring diagram:
third party image
My volatge reg.:
third party image
Like I said make sure all grnd. contacts are clean of all paint and dirt.
Also this pic. shows how to polarize the charging system. When you polarize, have the key Off....engine NOT running!!!!! !!!
Report back with your results please!!!
Hope this helps.
Gary :)
Bob
05-18-2008 20:19:05
Have you actually checked the generator's output voltage?
Then (temporaily, for testing) full-field it by grounding the generator's "F" terminal. What does THAT do to the generator's output voltage?
Be SURE the generator AND the regulator are grounded to clean metal (no rust or nice fresh paint).
