Dang!I thought I had everything covered on my 1952 8N springtime tune-up - Starter overhauled, new head gasket, new wiring harness, new plugs, points & condenser. Carb cleaned and rebuilt with basic gasket set. Fresh gas. Started her up, and she ran GREAT with plenty of power - I was able to run the brush hog for about 3 hours, absolutely no problems. "Oh, you elite tractor mechanic, you" I was thinking to myself. Then I went in for dinner. I come out to start it up - the starter cranks but the engine won't start. It will a-l-m-o-s-t start - enough to release the Bendix on the starter, but it won't start or idle. I got spark. I opened the drain on the carb and yup, there is gas flow. If I spray a little starting fluid into the carb it'll catch and run for a second. Any idea's as to what's going on? I don't "see" any cranks in the manifold, and the tractor was running perfectly when I shut it down. I let it cool down for a few hours, but it still refuses to start.
