Order Ford 8N Parts Online
8n vs 9n
rst277
05-19-2008 18:29:20
I"m looking at buying a tractor. I"m stuck between an 8n and a 9n both in good shape, the only difference is the price. Is the 8n"s 4 spd worth an extra $500? I am going to do some light grass mowing, level the lane with a 5" blade and maybe plow the garden. What do you"all think?? Thanks.
soundguy
05-20-2008 12:59:21
 Re: 8n vs 9n in reply to rst277, 05-19-2008 18:29:20
As others point out.. it is not only an extra gear difference. but different brake arangement.. possibly another distrib arangement.. position control, foot boards. and a tapped diffy for a swinging drawbar.. bracket... etc... plus it will be newer. That said.. whichever one is in the best condition is likely the better machine in a given price range.. not alot you CAN'T do with a 9N that ou CAN do with an 8N
soundguy
tatanka
05-20-2008 11:24:07
I have a 50's 8N with the side mount dist. A hole lot easier to change point ect than the front mount dist.
LeeMo
05-20-2008 13:29:54
 Re: 8n vs 9n in reply to tatanka, 05-20-2008 11:24:07
I have both front mount and side mount 8Ns and don't understand why the side mount seems that much easier to you. Taking out the two bolts that hold in a front mount is easy enough. Would you care to elaborate?
LeeMo
05-20-2008 09:01:45
I prefer the brake pedal arrangement and 4 speed transmission in an 8N over the 9N or 2N setup and the position control for the hydraulics is also a plus but Zane Sherman can take care of that for a small fee with the Zane Thang for 9Ns and 2Ns. I've owned and worked both machines and if the $500 more for the 8N wasn't going to break my bank I'd go with that. Either machine is a great old workhorse though.
36 coupe
05-20-2008 02:44:41
9n wont take a stationary hitch the comes in handy for pulling a trailer.I could not use the 3 point on my 640 to run a baler.There are some jobs that just dont work right on the 3 point.A wood trailer that is loaded a bit heavy behind the axle will push the 3 point upward at times.
Hobo,NC
05-19-2008 19:21:59
It would help if you told the price other than a $500 difference,,,, If both are in good condition and say 2K for the 9 and 2500 for the 8,,, I would pay the difference,,, if the 8 has a side mount distributor ell yell and both position control and draft control ell yell I would upgrade for 500,,, the mid 50 to 52 is the better,,, but a 9/2 n will do the same werk just does not have the upgrades the 8n has,,, its still hard to say less i seen'em
old
05-19-2008 19:15:20
Well if its the 8N with the side mount distributor yes its well worth the extra $500 but even if it isn't that extra gear does come in handy
Bob in Tennessee
05-19-2008 18:43:12
The 8N has several improvements over the 9n. What you are looking at may be a 2N. They are similar but the 2N's are more numerous. The 4 speed is very important to me because fourth gear will get you to where your going quick. Most 8N's also have a constant draft control that helps keep implements such as plows at a constant depth. That is a huge plus if you plow. The later 8's have a steering box that is easier to adjust. Drive each one carefully and use all gears. Test hydrolic lift with a heavy weight, such as a brush hog too see if the pump will lift quickly, then disengage PTO to see how long it takes for implement to fall.
All things being equal, I would pay the extra for the 8. I own two, as well as one 2N.
Dunk
05-19-2008 18:39:13
If they were both in the exact same shape, the 8N would be worth more than $500 difference to me.
In fact I wouldn't even consider owning a 9N, but that is just me, and what I want the tractor for, about the same things as you want the tractor for.
In fact, if I were buying, it would be hard to sell me an 8N.
I would be at least be wanting something with live PTO, and hydro.
I own 49 8N *236763*
Lance in Brenham, TX
05-19-2008 21:48:39
 Re: 8n vs 9n in reply to Dunk, 05-19-2008 18:39:13
how bout a cold foamy, Dunk?
Elvin Frank
05-19-2008 18:37:24
Different people will tell you different things. I personally have been on both tractors and my personal opinion is that one won't do anything the other on won't. Does either have a sherman transmission? If it was me and one had that it would be the one i'd buy. I do prefer the 4 speed transmission. John Smith have a very informative web site that has alot of usefull information on it. Something like Smiths old tractors. Either way I think you will be happy. Be sure to look at john smiths page especially his buying guide. Good luck and happy trails
Mr. Bob
05-20-2008 09:13:13
 Re: 8n vs 9n in reply to Elvin Frank, 05-19-2008 18:37:24
The Sherman tranny, Zane Thang, and underframe swinging drawbar make a real tractor out of a 2 or 9 N. The only advantage that I see an 8N having over this is the location of both brake pedals on same side. I prefer a 2N equipped as described over a "stock" 8N in that the 8N has a terribly fast reverse, and are more prone to axle leakage on brakes at rear wheels. To clarify my statement regarding "swinging drawbar" mounted under belly; yes, it can be very easily done. I've been using this one I installed on my 2N for years. Mr. Bob
