Little flush lever,below right of seat
russbWA
05-21-2008 18:32:55
My position control lever doesn't work any more. If I flip the lever up it still does what appears to be draft control, like normal to the down position of the lever.
I wonder of anyone has experienced this problem.
I suppose this will require pulling the Hydraulic Lift Cover. A good time to have a look see in the belly of the beast, er Evelyn.
jon
05-21-2008 20:20:08
 Re: Little flush lever,below right of seat in reply to russbWA, 05-21-2008 18:32:55
russbWA said: I wonder of anyone has experienced this problem.
Yep & I'm getting ready to do the same thing Russ. Go ahead & get yourself a 1" cam follower pin, not the stock 7/8".
If yours leaks down too easily like mine, might as well get the NAA piston for the ram cylinder cause this will be the easiest time to change it too.
I'll be posting updates when I get started.
Tom N MS
05-22-2008 04:04:12
 Re: Little flush lever,below right of seat in reply to jon, 05-21-2008 20:20:08
Yes you need the backup washer with the O-ring but NO you don't need to be ripped off and made to buy more than one. email me and I will tell you where to get parts.
russbWA
05-21-2008 21:27:34
Thanks for the reply jon. I am getting my courage up. Might even order piston and O ring tonight. There is some sort of spacer for the O ring listed on this site's store. I am not sure what they do. Anyone listening been down that road?
Hydraulic Lift Piston Washer - For 9N, 8N, 2N. Hydraulic Lift Piston Washer used with Piston #NAA530B. Comes in QTY of 5.Priced each. (Part No: NAA473A)
Dunk
05-21-2008 18:51:55
My bet would be the pin wore out that rides on the cam thing.
Yep, pull the cover, and Zane's jig might be worth the money.
And for real, it was hard to convince me!!!!
russbWA
05-21-2008 20:19:22
 Re: Little flush lever,below right of seat in reply to Dunk, 05-21-2008 18:51:55
Thanks Dunk and Sean for replies.
This might be a good time to get the later piston with O ring. Won't know if the cylinder is in good enough shape to work with O ring till I get there. Not sure there is anything wrong with the metal ring type piston, the O ring treatment sound better.
Sean (TX)
05-21-2008 18:42:27
 Re: Little flush lever,below right of seat in reply to Mike35, 05-21-2008 18:32:55
Pretty common problem...cant think of the fix at the moment....some one will chime in....
