Parts for leaking PTO shaft
Robert Bailey
06-14-1999 08:44:34
My PTO shaft is leaving a nice little puddle of fluid on the ground in the shed. I need to replace the PTO seal. Unfortunately, I am at work and my shop manual is at home. So inconvient! What parts do I need to order from my dealer to change the seal? I do not have a warm, fuzzy feeling that my local NH dealer knows the guts of an 8N any better than I do to give me good advise.
I see where there is a PTO bearing. Should I change that too at the same time? Is it hard to do?
bg
06-14-1999 12:22:59
 Re: Parts for leaking PTO shaft in reply to Robert Bailey, 06-14-1999 08:44:34
Don't remember if it comes as a kit or not. Seal is #9N 703, gasket is #9N 4129. Sleeve is 9N 735-B. Bearing is 9N 715-B or 715-C. Remove the four bolts, replace the seal and gasket, reinstall. If the bearing is loose or obviously very worn, replace it as well. If it seems solid and has no ragged or sharp edges, turns smoothly on the shaft and doesn't rattle around, it's probably OK.
Tommy (BOB YOU LISTED 9n #'s is this right ?)
06-15-1999 15:12:46
 Re: Re: Parts for leaking PTO shaft in reply to bg, 06-14-1999 12:22:59
Bob, I need the same thing for my '52.. Does the 9n prefix on the part number indicate 9n and 8n ???
Tommy
Robert Bailey
06-14-1999 12:40:05
Thanks! Exactly what I needed.
