Proof Meter
Order Ford 8N Parts Online
Early 8N ?
S. L. Breeden
06-17-1999 11:15:15
My early 8N (Front Distributer) has a cable comming out of the area behind the block at about 2:00. It looks like a speedometer cable and is currently coiled-up. There is also a hole (small diameter), not big enough to be for the dial of a proof meter, below the instrumewnt panel on the right side.
Question #1 - What is the existing cable for? I can find no info or pictures showing it.
Question #2 - Is a Proof Meter available for an early 8N? If so, what is a source?
David Sales
06-17-1999 12:12:18
 Re: Proof Meter - Early 8N ? in reply to S. L. Breeden, 06-17-1999 11:15:15
Looks like you may have a cable actuated Sherman transmission with just the remains of the cable exposed. Check out John Smith's excellent site for a photo of the cable and knob.
Regarding the proofmeter, new replacements meterheads and cables are available and can be retrofitted if you install a later style governor with the cable drive. To mount the proofmeter you will have to retrofit a later style dash with proofmeter hole or locally manufacture a way to hold the meter.
Good luck,
David
Here's the Link
06-17-1999 12:20:57
 Re: Re: Proof Meter - Early 8N ? in reply to David Sales, 06-17-1999 12:12:18
Bookmark John's site, he has some great photos.
