Sherman Transmission
Need Info
S. L. Breeden
06-18-1999 06:40:46
Found out yesterday taht my 8N has a Sherman transmisssion. Or so it appears. It is the type that has a knob sticking out of the dash board. I have reviewed my I&T manual and it does not cover the knob type, only the one with the lever. The I&T manual also states that parts are not available from FORD.
Question #1-Where can I get parts?
Question #2- Is there a book available on this type of transmission?
Question #3 - With this transmission, should I have 8 or 12 forword gears?
KCM
06-18-1999 12:18:11
 Re: Sherman Transmission - Need Info in reply to S. L. Breeden, 06-18-1999 06:40:46
Check out the Smith's 8N Ford Tractor web site. There is a picture of a cable type overdrive, which states that it is an early Sherman Overdrive (8 forward gears, 2 reverse). Also check past archive articles on the Sherman transmission. The cable has been discussed before.
Link
Dell (WA)
06-18-1999 10:06:10
Breeden..... If memory serves, I think the aux tranny with a push/pull cable/knob in dashboard is a "Parks" instead of the more common Sherman.
answer #1- All aux tranny parts are NLA to my knowledge
answer #2- try "www.n-news.com" the N-Newsletter is a great read and has an awesome "archive" with all sorts of manuals for sale including a "Sherman pkg"
answer #3- you should have 8 speeds foward if installed in a 8N.
Hope this helps..... ..Dell
