Order Ford 9N Parts Online
9nN Brake Bands
Phil (NJ)
06-18-1999 19:59:08
Yep, Don't have a Manual and out in the Boonies.
I have a Left brake shaft that is rusted, removed
tire but need advise on how to remove Brake Hub
1941 9n with Rivits
Thanks, Phil
Jay Andrews TX
06-18-1999 22:20:42
 Re: 9nN Brake Bands in reply to Phil (NJ), 06-18-1999 19:59:08
Phil, I will give you the instructions out of the IT manual for a 9N.....Remove the rear wheel and fender support brace. Remove the stud nut attaching the axle bearing retainer to the axle housing. Pull the axle shaft and brake as an assembly out of the axle housing. Turn brake adjuster eccentric counter-clockwise to back the brake shoes away from brake drum. Lift the brake backing plate off the retainer studs. Remove brake shoe retracting springs and hold down springs. Remove brake shoes. Hope this helps you..... .JAY
