Hello Del, The three sets of points in a regulator are operated by simple electromagnets which are NOT polarity sensitive. Each set of points is single-pole-single-throw and are opened by spring tension - not reverse polarity. HOWEVER The points themselves are made of different materials to reduce particle migration across the vibrating gaps - and longer life. That is why a positive ground regulator should NOT be used on a negative ground system, and visa versa. The pole shoes for the field windings in a generator, when originally installed - and sometimes after sitting idle for long periods, have no/not enough magnetic field and must be polarized such that the small amount of residual magnetism remaining will start the generator charging in the correct polarity. A generator should always be polarized when re-installed just to make sure that it's polarity is correct. Polarizing a generator is done simply by touching battery hot to the field terminal - with the case grounded. The armature does not require polarization. However a general, overall check of a generator can be made by jumpering the field and armature to battery and seeing if the armature turns. If it does, it is probably a good generator.With new bearings/bushings, a small turn by hand might be required to get it started. Do not continue for long. Generators make poor motors and can be smoked by this method. Toodle & Ooo Elvy
