What else besides an N?
SGT in MO
06-30-1999 10:22:49
Greetings.
Don't get me wrong, I like my 52 8N. It is a very good farmette tractor. A carry all, and boxblade have been swell tools for me to do the avg stuff round the 7-1/2 acres I toil on.
However, I need more hydraulic possibilities. I don't really like the add on idea and all the hassle of switching implements etc. It never fails I have 10 min of this task, 2 hours of this task and then 20 min of the other task. Switching and the dead PTO are just too bothersome. I do know the $2000 invested has given me the options I paid for.
What else (other tractor) is out there in the vicinity of $4000 and less that has live PTO and better hydraulic options. (loaders, backhoes). Is the 600 Ford a good alternative?
Don't really want to sell my 8N, but may have too.
Thanks in advance Steve
Mike H(MD)
07-02-1999 07:51:36
 Re: What else besides an N? in reply to SGT in MO, 06-30-1999 10:22:49
Steve
Your 8n will handle the rake and for your small area a sicle bar mower will do just fine. You can also look for a bailer that has its own moter instead of pto driven model. Just my $.02...Mike
Larry 8N75381
07-02-1999 05:06:58
I'll "vote" also for the 3000. I have one and like it very much. With it and my uncle's 8N I can get a lot of "stuff" done. On one hand it seems like a big tractor for 7.5 ac. BUT I have a buddy that has one and only has 3.5 ac. He did some custom bush hogging around his area, so that might be something you could do to justify the bigger tractor
Around here (northern Virginia) they go for $4-5K, but you may be able to find one cheaper at an auction. I had a tractor parts yard guy tell me that he does not see hardly any come in because they are so popular, people fix them rather than junk them. At 10 hp more and 1000 lb heavier, they can do a lot of work so are worth the difference.
A three cylinder 2000 may be OK for you also. The only difference is derated HP by dropping rating RPM from 2000 to 1900 AND draft control only for compression on the top link - just like 8N. The 3000 has draft control for BOTH compression (pulling a plow) and tension - like pushing a rear blade. If you keep you eye out you may also find the later versions of the 2-3000 such as a 3300 or 3600, but then price may be too high.
Good luck, AND figure some way to keep the 8N too!!
thad
07-01-1999 18:45:40
I hate to say it, but an oliver super 55 would be better. Don't get me wrong, I like my 9n, but the super 55 has more opportunities.
Al
06-30-1999 17:21:34
I agree with Nolan regarding looking at an 800 or a 3000 Ford. His father-in-law stole his 3000 diesel at $3500: That would be a steal even for a gasoline model. I love my 3000, but I'm glad I kept the 8N: It's very convenient to have two tractors so you don't spend so much time switching implements.
Personally, I'd stay with a tractor with a three point hitch. You can add a swinging drawbar for pull type implements and still be able to use all the equipment you purchased for your 8N.
Nolan
06-30-1999 10:33:34
For $4k, I'd not bother with the 600, but consider at least the 800 series (bigger,etc). And you could find your way up into the 1000 series machines even. My father-in-law purchased a 3000 diesel at auction for around $3500.
Depending on your area and your personality, you may want to expand yourself out completely and consider stepping away from Ford, and going with something else that isn't popular, particularly in your area. MM's go dirt cheap here, and will work just about anything else into the ground.
Now about that hitching issue, er, just about everything uses a standard category I hitch, and they are all equally difficult to use. Some folks love this pipe hitching assist tool I've seen. It's about a yard long pipe that you snake through the hitch arm ball and then onto the appropriate impliment pin. You then yank, cuss and kick things to slip the hitch arm on. It probably does help by the increased leverage.
There are quick hitches that you can install onto the arms of any lift, whereby you simply back up to the impliment and it "snaps" itself into place. You may wish to consider that.
And you may want to consider how you put your impliments away. I too often have to switch things around. And before I spent some time out in the yard making a nice neat level and orderly arrangment of impliments, I'd spend a lot more time cursing trying to line things up to hitch them on.
jrmo
07-02-1999 06:57:26
 Re: Re: What else besides an N? in reply to Nolan, 06-30-1999 10:33:34
once I finally got arround to organizing my impiments it helped a great deal. Also made room for a boat in the barn.
jrmo
07-02-1999 06:57:18
SGT in MO
06-30-1999 10:27:41
P.S. I would like to bale sq bales with the tractor. 3-1/2 acres are in alfalfa and I want to stop giving away half of it.
Bill OH
07-02-1999 06:32:28
 Re: Re: What else besides an N? in reply to SGT in MO, 06-30-1999 10:27:41
Now you are talking a bit different animal. Definately need live PTO and probably something around 40 plus h.p., the more plus the better. (Board, comments?). The 8N pulls wagons great! You want to consider if the cost of mower, rake, baler and wagons is worth it for that small acreage of hay. I think ya might find half the production is worth it. Good luck.
