A Problem?
Ron from IL
07-02-1999 10:37:21
Hi Guys,
This may be ore of a complaint than a problem, but the ol' 2N's front axle support rods (sorry, I don't have my I&T manual handy, and that may not be the right term) 'clanks' constantly, obvoiusly because its worn and loose. Can I tighten this up easily without replacing the rod and socket itself? Is this a real problem or just an annoyance? Any comments would appreciated!
Thanks.
Ron
Carl in Vermont
07-02-1999 14:17:15
 Re: A Problem? in reply to Ron from IL, 07-02-1999 10:37:21
Had the same problem- rattle drove me nuts until I figured out where it came from. I drove the pin out, shimmed the hole with old reliable JB (junk box) shim stock (tomato can, gutter piece or what have you) and solved the problem. Use stuff that will just let you pound the pin back in. Now that that annoyance is gone, I can hear engine noises, transmission howls, gear crunches better. Heh heh heh. Carl in Vermont
