Order Ford 8N Parts Online
Ford 8n hydraulics
ron long
07-03-1999 20:07:15
can anyone help me correct a problem with my hydraylics, more specifically, my flow control lever. When using a two-bottom plow, the adjusment lever in full "up", and the flow control lever in the horizontal position at the end of a furrow, I have to press down on the the flow control lever in order to raise my plows. If anyone could shed some light on this problem, I would appreciate the help.
George
07-03-1999 20:16:37
 Re: ford 8n hydraulics in reply to ron long, 07-03-1999 20:07:15
There is an internal adjustment for the hydrylics. A good shop mannal will tell you how to do this I woould also look into changing the lift piston while I had it apart. It is VERY simple to do.
