Paul..... ..4.5 volts on a 6 volt side mount coil 12 volt conversion is just a "tad low" but will work. Not great maybe, but works; as long as the sparkplug gap is 0.025. Your 12 to 6 volt dropping resistor is too many ohms (actually, too many fractions of an ohm). If your tractor "misses under heavy load", you got "low sparkies" and will have to figgure out how to get more volts at the coil. Several ways: 1) different value 12 volt dropping resistor 2) there is always the possibility that your ignition switch contacts are "gunked-up" and are only supplying 10 volts or so to the dropping resistor and thus low volts to your ignition coil. Check with a jumper wire around your ignition key switch contacts, if coil volts go up, you know the drill, replace the ignition switch. There should be a molded + and - on the top of the ignition coil, be certain that coil + is connected to battery +, otherwize you can loose up to 25% of of your sparkies. Coil - goes to battery - (ground) through the points. Personally, I like to use a real 12 volt (no ballast resistor) coil, some times called hot-rod coils. Actually, some of the later model Ford 12 volt tractor coils look just like an original 8N coil if you are concerned about "originality" and who cares if you have already changed to an alternator. (grin) A good parts "person" should be able to help you out. Watch out there are 12 volt system coils that are designed to run on 9 volts with a "ballast resistor" that drops the 12 volts to 9 volt for regular running but by-passes the ballast resistor during starting, thus putting 12 volts on a 9 volt coil for eazier starting. As I recommended, get the new "improved" starter drive. A good parts "person" should beable to help you get the right starter drive. I don't know the "official" part number and the catalogs use their own order numbers anyway. Hope this helps..... ..Dell
