Front wheel studs- frozen stiff!
Reid Davis
02-13-2000 16:59:36
Hello out there in tractor land. I went to fix a flat on the 2N I bought to restore and found out the the wheel studs are completely siezed in the hub with corrosion after years of neglect and exposure to the elements. Would anyone have an idea as to the best way to get the studs out of the hub so I can replace them with new ones. I am tempted just to heat them up and bash them with my 2lb sledge, but I don' t want to do it with out having a little advice. For instance are these studs in bushings or a they just straight in like a bolt? Thanks,
Reid
Randall(AL)
02-14-2000 08:22:03
 Re: Front wheel studs- frozen stiff! in reply to Reid Davis, 02-13-2000 16:59:36
If you have access to an air wrench, pentrate oil them today and put it to em tommorrow. If they break which one of them probably will drive it out and put in a new stud and nut. If you've ever done it on a car its basically the same difference just not as much trouble.
