Oil Blow by
AL@NC
07-07-1999 05:37:34
What besides rings will cause oil blow by at both the oil filler tube and valve cover breather on my Jubilee? I also get a little gray smoke at the exhaust but not bad. The compression runs from 115, 110, 105 and 120.
Stan
07-08-1999 00:02:14
 Re: Oil Blow by in reply to AL@NC, 07-07-1999 05:37:34
Could it be your crankcase breather is plugged?
Good luck Stan
Dell (WA)
07-07-1999 10:39:42
Al..... .I would suspect the valve stem seals on your OHV Jubie engine. Compression is "respectable" in my opinion. Do a valve job, You'll have to take the head off anyway to get to the seals.
Just my opinion..... ..Dell
