Wagner Loader Parts
Alan
07-08-1999 12:31:22
I need a drive assembly to hook up a Wagner Loader (WM3) to my 8n. I already have the pump, but I need the pully, rod, and related stuff. Any information on where I can find these parts please let me know. Also Whatever happened to the Wagner Iron Works Company that made these fine inpliments?
Thank you!!!
Grower123@aol.com
Kevin (WA)
07-09-1999 12:25:50
 Re: Wagner Loader Parts in reply to Alan, 07-08-1999 12:31:22
Alen,
Goto Walts Tractor, they are listed under the parts & supplies on the site. When you get there click on Ford, then click on miscellaneous, and then click on loader pump parts. They have several different parts configurations so you should be able to find what you'll need to make the hook up.
Good Luck, Kevin
SMITTY FROM SO.CAL
07-08-1999 22:01:14
I JUST FINISHED DOING WHAT YOU WANT TO DO SO.. I BOUGHT MY PULLEY ADAPTER FROM CENTRAL FARM. (THEY DONT HAVE A WEBSITE) I BOUGHT THE SHAFT (SPLINE ON ONE END ONLY) FROM A FORD NEW HOLLAND DEALER IN BAKERSFIELD THE PULLEY ADAPTER BOLTS ON TO FRONT OF THE EXISTING PULLEY AND THE CENTER RECIEVES THE SPLINED SHAFT. THEN YOU CAN USE A LOVEJOY COUPLING TO ATTACH SHAFT TO PUMP. NOW HERE IS THE FUN PART YOU HAVE TO UNDO ONE SIDE OF THE FRONT AXLE TO SWING IT AWAY FOR ACCESS. NO BIGGIE USE BREAK FREE OR ANY OTHER TYPE OF LUBRICANT ON THOSE NUTS EVERYTIME. I HAVE GONE THROUGH SEVERAL CANS AND IT MAKES A DIFFERENCE. WHO KNOWS WHEN IF EVER THEY WERE LOOSENED. IF YOU WANT MORE INFO LET ME KNOW.
