Sherman Transmission
S. L. Breeden
07-19-1999 14:18:58
The knob for the shift cable on my 8N Sherman is gone.
How can I check it out to see if it works & where might I get parts?
Thanks!
Kevin (WA)
07-20-1999 05:34:04
 Re: Sherman Transmission in reply to S. L. Breeden, 07-19-1999 14:18:58
If you discription is correct in that the transmission is shifted by way of a cable and not a lever, I believe that you have a Parks and not a Sherman. All of the Sherman's that I know about shift with a lever on the left side of the bellhousing. If you're looking for a replacement knob try looking at NAPA for a PTO shift cable knob, you'll need to take the thread size with you. If the parts your looking for a internal to the transmission your out of luck with the exception of maybe the seals and bearings which you should be able to get at a good bearing house.
Good Luck, Kevin (WA)
