Hand Crank
S. L. Breeden
07-23-1999 12:57:58
Did the 8N Ford come with a hand engine crank?
Was a hand crank available as an option?
If it will work on an 8N, where can I get one?
Regards
Mike G.
07-23-1999 19:14:56
 Re: Hand Crank in reply to S. L. Breeden, 07-23-1999 12:57:58
A big AMEN to that!
brs
MIke G - 8N300465
bg
07-23-1999 19:14:21
I saw a local 8N w/ a handcrank that even had a clip-on bracket on the running board. You can make a crank with a piece of 5/8"(or whatever fits) rod and a roll pin and a torch. We used to have a 2N w/ a crank and it always started on the 2nd pull.
Ed Gooding (VA)
07-24-1999 07:10:59
 Re: Re: Hand Crank in reply to bg, 07-23-1999 19:14:21
I took a picture of mine and edited it to display dimensions. If anyone wants a copy to make one, give me an email holler and I'll send it your way.
Regards..... .....Ed
'52 8N475798
Ed Gooding (VA)
07-23-1999 16:05:08
I believe hand cranks came with the included tool kits. I wouldn't be surprised if you could still buy one from a New-Holland dealer. Or, at least from on of the advertisers here on YT. However, these suckers are more dangerous than your mother-in-law during menopause! Great way to get your thumb or wrist broken when they kick back on you.
fwiw..... .....Ed
'52 8N475798
Kevin
07-23-1999 22:24:45
 Re: Re: Hand Crank in reply to Ed Gooding (VA), 07-23-1999 16:05:08
To avoid a broken thumb I was always told make sure your thumb is pointing forward, because with it pointing forward there's nothing to get your thumb caught on.
Ed Gooding (VA)
07-24-1999 07:11:56
 Re: Re: Re: Hand Crank in reply to Kevin, 07-23-1999 22:24:45
Which way do you hold your wrist (grin)?
