Exhaust valves
Banks
07-24-1999 20:14:34
I am rebuiling a '51 8N. Intake valves have the two piece keepers on bottom of valve stem. Exhaust valves have a retaining clip on them and I'm not sure how to remove them. Any suggestions?
David (La)
07-25-1999 06:26:07
 Re: exhaust valves in reply to Banks, 07-24-1999 20:14:34
Not sure if you mean how to remove the valves from the block or how to remove the springs from the valves after out of the block?
To remove the whole valve assembly from block, there is a retainer clip at the top of the spring with a tang facing out and a hole in it. You can pull it out with some vice grips or use a pointed tool to hook it like the manual says (it helps to push the spring down and take some load off the clip). This will allow the whole assembly to come out the top of the block.
The free rotating exhaust valves are retained to the spring with split horse shoes inside the bottom keeper. Take the lifter cup off ( its loose) and pull back some on the spring by hand and the horse shoes will fall out.
