Leaking 3pt hitch arms
Ron in Can
08-01-1999 19:58:36
I have a 47 2n and the mtn for the 3pt hitch arms leak oil is there supposed to be a gasket between the mtn and the axle housing and what is the torque for the nut that is on the inside of the axle tube i have NO manual for this tractor yet but i,m working on it. thanks
Jerry Cummings (NH)
08-02-1999 05:32:58
 Re: leaking 3pt hitch arms in reply to Ron in Can, 08-01-1999 19:58:36
How big a job would it be for a novice to get
at this nut? I've never even taken one of the
rear tires off on my 8N!
Also, what's the best way to evaluate whether
it's worth doing at all? If I understand this
problem it's possible that the casting can
be "wallered" out so that no manner of
tightening will matter for very long?
Thanks,
Jerry
David
08-02-1999 04:34:22
If I am not mistaken the nut inside torques to 150 ft/lbs. I know it sounds like a lot but a little RTV and mine quit leaking.
llamas
08-02-1999 03:14:48
Yes, there is supposed to be a gasket. It is "no longer serviced" by Ford-NH. So get out your rubberized cork and your gasket punches. It's not hard to make one.
I don't know a torque number for the nut. I do 'em up with a 24" ratchet until I grunt, not too hard. As rough as it is to get to these, a good healthy layer of gasket cement everywhere it might leak is probably good insurance.
llater,
llamas
