Order Ford 9N Parts Online
1941 9N Tractor Wiring cooling
Ron Ott
08-04-1999 05:14:19
Did 21 years in the Navy was a good sailor but aint worth a darn as a farmer. I have two questions 1 Would this model Ford/Ferguson be a Positive Ground? (positive battery pole going to ground). and 2: Is the fan supposed blow air
thru the Radiator (from the inside out)???
DE
08-04-1999 05:57:20
 Re: 1941 9N Tractor Wiring cooling in reply to Ron Ott, 08-04-1999 05:14:19
Answers are yes and yes. All N's were originally positive ground although some have been modified. The 9N came, for some period, with a pusher fan blade which sounds like what you have. They weren't very popular and the change was made to a puller blade at some point. You can replace yours with a new pull blade (or look for an original) if you don't like the pusher.
Ron Ott
08-04-1999 12:50:54
 Re: Re: 1941 9N Tractor Wiring cooling in reply to DE, 08-04-1999 05:57:20
Thanks a million DE, you sure made my problems seem a lot smaller, I really can't see how you could work a field in 80 or 90 degree weather with this pusher fan, maybe, when it was new it worked better. Thanks again.
