Order Ford 8N Parts Online
8N maybe bad transmission
Phil
02-19-2000 16:59:06
Here is the problem, I use my 8N here on the farm lately I have noticed that you can put in it gear let out the clutch and if you are on a hill or trying to pull something the tractor will not pull. The wheels will not spin or anything, Its in gear it just won't do anything except if it is on flat ground. It does the same thing forward or backward. I think the transmission is goofed up. Anybody got any ideas.
Dave Todd
02-19-2000 17:50:02
 Re: 8N maybe bad transmission in reply to Phil, 02-19-2000 16:59:06
I think Ray is right on. My 8n has a weak clutch, but not as weak as yours. It will slip just a bit when conditions are just right. Someday, when I tear it down for that Loooong overdo rebuild, I'll put a new clutch in it as well.
Dave
raytasch
02-19-2000 17:40:27
Sounds like you may have a sliping clutch. How much free play do you have in the clutch? Should be able to push the clutch 3/4" before you feel some resistance. ray
