Front Pulley
8N3215
02-20-2000 21:47:35
I have an 8N with the front mount distributor. Can I put a pulley on the front for a hydraulic pump for an attachment? Looking at it there does not appear to be enough room?
Mike (NM) '49 8N
02-20-2000 22:21:45
 Re: Front Pulley in reply to 8N3215, 02-20-2000 21:47:35
I had to replace my front pulley with one drilled and tapped for a special attatchement. The pump shaft is driven directly by the pulley and runs through the king pin. The pump is then attatched in front of the grill. When looking at the front of your tractor you will notice a small hole in the bottom of the grill for this shaft. My pump sits on the front of the loader I will someday install.
