Compression
RJ
08-14-1999 19:35:41
What is the min. compression PSIG for 1940 9N. Also Torque spec.s for cylinder head.
Claus
08-15-1999 04:07:05
 Re: Compression in reply to RJ, 08-14-1999 19:35:41
Minimum compression pressure is 90 psi. This is dry with the engine at proper operating temperature with the throttle wide open. It is important that the lowest reading is within 75% of the highest. 50 to 55 ft lbs for stud nuts. 65 to 70 ft lbs for bolts. Yours should have the stud nuts.
Happy Motoring
Claus
