CastingDate
Poke
02-21-2000 07:24:37
I have 9n #25376 1940, the casting numbers on the left rearaxle housing is 9n 4013 B2..My guess is the 40 means yr. 13??? B is for Feb and the2 is the date. What does the 13 represent , or am I all wet about so far?
Jim(UT)
02-21-2000 17:29:57
 Re: CastingDate in reply to Poke, 02-21-2000 07:24:37
I'm not expert in this, yet, but I believe the number you are seeing is the part number for the axle. I saw one over the weekend that had the same number on the axle and then a date "3-3-44" stamped right under the 9N 4013 B2. Others use a 3 or 4 character date code that uses a letter to indicate month, 2 digits for day, and 1 digit for year so that A156 translates to January 15, 1946 where A=Jan (B=Feb, C=Mar, etc), 15=15th day of the month and 6=1946. It appears that the axle casting dates did not follow a firm unalterable format. If anyone can shed more light on this, I'd be interested.
Mason W.V.
02-21-2000 18:25:21
 Re: Re: CastingDate in reply to Jim(UT), 02-21-2000 17:29:57
The # you refer to is Ford's original part # went through this my self just A couple o' weeks ago.. curiosity had the best of me ..Hope this helps.. C-YA Mason W.V.
