I have a coule of questions about troubles I am having with my 9N. 1. The power take off will "pop out" when a strain is out on it (like trying to cut 10" grass) with a brush hog. I have owned the tractor for 7 years and this always happened every now and then, but now it has gotten so bad I can't even mow. Any ideas as to what to start looking at? 2. I have almost no power under a load. The tractor will idle fine and respond to throttle increases without missing a beat, but again, when mowing, it will bog down and die (assuming I can keep the PTO engaged). I had to rewire the entire tractor earlier this year, and it did run fine after that....for a while. By reading this page I know I need to check the point gap, but I have questions about the carburetor. The IT manual I have just tells that the tractor was made with 1 of a couple of types of carbs and what the float height should be, but nothing else. I'm not even sure what the 2 adjustments are for (I did manage to figure out the idle adjust). I assume the small screw is an air/fuel mixture, but the large screw ? (the one toward the front of the tractor ?) I have disassembled and cleaned all the jets, etc, but it seems that neither adjustment makes any difference. Can someone enlighten me? Thanks
