Order Ford 8N Parts Online
8N FORD HYDRAULICS
PA-DAVE
08-21-1999 07:35:39
Last year i honed and put in a new piston and ring along with a new safety valve,my problem now is when the arms are up it kicks out the hydraulic touch control leaver about 1/2 way down.The only way i can keep the arms up is to hold on too the leaver.Anybody have any ideas ?
bg
08-21-1999 09:52:44
 Re: 8N FORD HYDRAULICS in reply to PA-DAVE, 08-21-1999 07:35:39
Do you mean that when the lift is all the way up, the touch control handle just falls down, or can you feel pressure on it? If it just falls, try tightening the friction disc nut and check if your friction disc is intact and finctional. If it's pressure causing it, I'd suspect a faulty valve:intake, exhaust or relief.
PA-DAVE
08-22-1999 07:14:14
 Re: Re: 8N FORD HYDRAULICS in reply to bg, 08-21-1999 09:52:44
Yes i can feel pressure on the hydraulic touch control lever wanting to pull it down when the arms are being raised.
