Hydraulics for 2n
Ron in Can
08-22-1999 22:23:15
Ihear on the board about people that have front end loaders on 2n,s how do you get the hydraulic power for such an thing i have not found any where to get pressure from the hyd pump to a cyl and then back to the trany do you have to mount an aux hyd pump and a tank to get this or am i missing something when i am looking thanks
Tommy(MO)
08-23-1999 15:03:26
 Re: hydraulics for 2n in reply to Ron in Can, 08-22-1999 22:23:15
I actually looked at one of these a week ago. It's mounted on a 9N or 2N and the whole rig was painted yellow. It had the front mounted pump. The price tag was $2100. It was a little rough, but it ran. I thought about buying it, but have no need for the loader and no easy source to remove it. I'ld be happy to pass on the info if you're interested.
Later.....Tommy
llamas
08-23-1999 03:00:58
There were loaders sold for these tractors in the 40s and 50s which ran off the internal hydraulics. There's a port on the right side of the hydraulic case where you can tap pump pressure. You have to chain the hitch arms down to get the pressure to transfer to the loader. Not a very satisfactory system, non-live, and they're slow.
A much better system is to mount a hydraulic pump to the front of the crankshaft, with its own reservoir and control valves. Most of the major suppliers ell the necessary pumps, crank pulleys and adapters to do this.
llater,
llamas
