12volt coil conversion
Ron in Can
08-23-1999 21:52:52
i am trying to convert my tractor over to 12volt the generator bite the dust and i got a one wire alt (cheap) so it was time for the switch but i am having trouble with the coil trying to get it by passed by the new one any ideas on how to get the hi tension lead to the dist cap well still having the original coil still in place thanks for any and ideas Ron in Can
Phil (NJ)
08-28-1999 00:48:47
 Re: 12volt coil conversion in reply to Ron in Can , 08-23-1999 21:52:52
Ron, One method used is to drill a hole in the side
of the Coil (near the Contact) and use "Wire" hi-voltage cable to connect to the contact.
The Low voltage wire also drilled through the other side but connected with a spade lug to the
contact screw (old spring cut off coil)
Hope this helps,
llamas
08-24-1999 03:04:32
You can do this if you really want to, by drilling off the heads of the rivets that hold the old coil assembly together, prying the case apart, and hollowing out the guts. It's all potted in a tar-like substance. You can then access the contacts in the case and attach wires.
It's much easier, though, to just get a $2 voltage reducer (General part # RU100 or equivalent) and wire that into the coil lead. In conjunction with the existing ignition resistor, this will keep the coil voltage down to about 3.5 volts, and allows you to use the original coil. You can also buy an original-style coil wound for the 12 volt application which will fit the distributor but runs at 12 volts - these are about $30. Several of the sponsors of this site sell this style of coil.
llater,
llamas
Matt
08-25-1999 19:53:37
 Re: Re: 12volt coil conversion in reply to llamas, 08-24-1999 03:04:32
I got my 12 volt coil for front mount distributor at my local New Holland dealer for $32. Hope this helps.
