Compression I,II,III,IV
RJ Guill
08-24-1999 08:53:43
The 9N in now running. Thanks for all the usefull infomation. A little smoke out the breather otherwise ok! A combination of minor things had kept tractor fron starting after tractor had set idle for so many years. After getting the compression back in #1 cylinder (a piece of wire stuck under intake valve). Tractor was not turning over fast enough, connection on starter motor was corroded, once the cranking speed increased everything fell into place.
Thanks,
RJ
thanks for follow up........Dell (WA)
08-25-1999 07:40:59
 Re: Compression I,II,III,IV in reply to RJ Guill, 08-24-1999 08:53:43
Sometimes it a big obvious thing, sometimes its a small obscure thing. By sharing info, we all can get a little bit smarter. Thanks for follow up..... .Dell
