Stuff
Phil (NJ)
08-28-1999 13:14:50
1)I have a small leak from my Frost plugs, what is confusing me is they are flush with the block. I am familiar with the Bowl and the sauser, and both types when installed are not flush. Are the N
frost plugs special??
2) The Cast Iron (original) PTO cover will not fit, too short. The Shaft has been changed out and has the Quick-conn grove which makes the shaft longer. Need a 1" extention for my Cover,
Any suggestions?
Phil
AL@NC
08-28-1999 15:34:44
 Re: Stuff in reply to Phil (NJ), 08-28-1999 13:14:50
My dad use to install freeze (frost?) plugs backwards feeling you got a better seal. This would put them flush to the block. You use to be able to get the indivedual ones out of brass also.
Claus
08-28-1999 14:33:59
Stevens AG has the PTO covers for $8.95. As you found out the old covers for the 1 1/8 shaft are too short.
Happy Motoring
claus
jon
08-28-1999 13:39:05
Might try some JB Weld on the plugs as a temporary fix (maybe permanent).
Seems I saw a longer PTO cover somewhere but can't remember where. I think it's out there so don't give up.
