Order Ford 8N Parts Online
'New' 8N
Charlie in TX
08-28-1999 19:50:06
Recently bought a '52 8N. Has a couple of minor problems.
1. The sedement bowl/shut-off valve leaks. Would like to know if there is an easy way to repair it or should I just replace it.
2. The ORC wobbles. Is it repacement time?
Check ya
Chuck
Alex Ballarotto
05-22-2001 17:20:26
 Re: 'New' 8N in reply to Charlie in TX, 08-28-1999 19:50:06
I own a 8-N Ford tractor...I need the power take-off assembly...I must have a 1 1/18" I cannot use a larger one.... because the tractor already has an adapter on it. If you know where I can find one please let me know.
Thank you.
Mac(MI)
08-30-1999 05:16:46
Dell is the ORC preacher, so I'll leave that one alone. As for the sediment bowl leaking, there is a gasket/screen (rebuild kit), for this that costs less than $5.00. Buy it and rebuild and all your troubles will be solved. My experience is that you probably have no gasket to seal too and could strip your post or crush your bowl by over-tightening.
wobbling?.......Dell (WA)
08-29-1999 06:35:31
Charlie..... .if it wobbles, I'd seriously suggest replacing the ORC. $60 cheep insurance..... ..Dell
Charlie in TX Thanks Dell
08-30-1999 00:01:09
 Re: Re: 'New' 8N in reply to wobbling?.......Dell (WA), 08-29-1999 06:35:31
It's will not be used until replaced
Jim(CA)
08-28-1999 21:18:57
If the valve is leaking around the stem I beleive (without looking)that it has a nut that can be tightened to compress a packing. Matts right, Their not expensive..
Steve (IA)
08-29-1999 03:07:40
 Re: Re: 'New' 8N in reply to Jim(CA), 08-28-1999 21:18:57
Yup, the nut can be tightened to stop stem leaks. If you decide to replace, be very careful about cross threading the new valve during installation. Good luck.
Matt
08-28-1999 20:14:07
Chuck, 1. Replace it. I got one from a New Holland dealer for about $15. Be sure to drain the tank before you remove the old one. 2. Yes, it's replacement time. Right, Dell(WA)?
