Order Ford 8N Parts Online
8n Running hot
Randy
08-30-1999 13:06:35
I have a 1947 8n, it has a new water pump, cleaned out the radiator and put in new anti freeze and water. It still gets hot when I use it hard cultivating my trees and arena????? Thanks in advance!!!!!
Tom A in Middletown MD
08-31-1999 04:52:16
 Re: 8n Running hot in reply to Randy, 08-30-1999 13:06:35
Had similar problem--not one to mess around, I replaced all key cooling system parts except the radiator, which I flushed internally. Finally flushed out the radiator fins where the air flows with garden hose...lots of seeds, little plant parts and perhaps 50 years of mud flowed out...and I'd swear it looked clean when I inspected it! Anyway, no overheating since.
good luck,
tom
Fred(Ia)
08-30-1999 17:08:26
Howdy Randy, You say it's getting hot, what are the symtoms? Boiling over, or does it just seem like there's a lot of heat coming from up front. A lot of the fans on N's are puller fans, the fan is pulling the air from in front of the grill and blowing it back towards the operator. It can seem like the engine is too hot but in fact it is normal. N's have a very large cooling system for the engine size. Fred
Randy
08-31-1999 08:07:24
 Re: Re: 8n Running hot in reply to Fred(Ia), 08-30-1999 17:08:26
It is boiling over!!!!! !!
Fred(Ia)
08-31-1999 17:01:50
 Re: Re: Re: 8n Running hot in reply to Randy, 08-31-1999 08:07:24
Randy, I'd also check operation of thermostat in upper hose. Might be wise to replace anyway as long as your there. Good luck. Fred
