What the N is it?
Ron ...ski
08-30-1999 15:28:23
I cannot read a s/n on side of engine but a name plate on the engine says type 4-28 and serial number 2790 C2CS. Casting numbers read ND-24D 8N-B and 9N7.006-B. Any help would be greatly appreciated.
EricG.NH
08-30-1999 18:02:53
 Re: What the N is it? in reply to Ron ...ski, 08-30-1999 15:28:23
This designation was used on the Ford Industrial engines. On the metal tag that has the type number, 4-28, and the serial number, 2790 C2CS, it should say Ford Industrial Engine, above the numbers. Eric
Larry 8N75381
08-30-1999 16:33:47
The raised cast in 8N-B is found on the engine block for the side distributer 8N. The front and side dist. blocks are different for at least one reason, that is, the oilbreather tube on the side dist. block had to be moved to the rear to allow the switch of the generator from the right side (front dist) to the left so the generator would clear it.
The name plate sounds like the engine was rebuilt and tagged by the rebuilder.
