Positive Ground
Order Ford 8N Parts Online
8N ford
Russ
09-05-1999 08:49:04
I just purchased an 8N Ford Tractor and it has a postive ground. Do all 8N's have postive grounds and if so, has anyone changed them to negative?
EricG.NH
09-06-1999 05:25:43
 Re: Positive Ground - 8N ford in reply to Russ, 09-05-1999 08:49:04
Aside from what Matt said, I can't think of any reason to change to negative ground. The positive ground isn't restrictive in any way. And in addition to what Claus said about the ignition coil, I believe the generator has to be re-polarized as well when the battery polarity is changed. Eric
Matt
09-05-1999 18:05:53
From what I've learned about this subject, they are usually changed to negative ground only when converting from 6 to 12 volt.
Claus
09-05-1999 08:57:10
Yes and yes. If you have an early 8n with a front mounted distributor, I would not change because you are reversing the coil polarity. This will give you some reduced Spark Current. This reduced current may only be noticeable under full engine load.
Happy Motoring
CLaus
