Diode vs. sidemarker light on 12v
Alan in MO
09-08-1999 12:00:40
Which one should I use? I've seen references to both is one better then the other?
David (la)
09-08-1999 13:09:10
 Re: diode vs. sidemarker light on 12v in reply to Alan in MO, 09-08-1999 12:00:40
I used the radio shack 10ohm 10watt resistor with no problems. It looks like a ceramic stick with a wire out each end, about 1\4" square by 2" long.
Two come in a package, you can have my extra if you can't find a radio shack nearby.
Claus
09-08-1999 12:28:51
Delco recommends a 10 ohm 7 watt resistor. You can use Radio Shack 10 ohm 10 watt P Nr. 271-132. The idiot light and diode will work also. The resistor is probably easier to mount.
Happy Motoring
Claus
