Order Ford 8N Parts Online
Technical question on 8N engine
Arlie
09-18-1999 15:57:55
How come the difference in compression ratios between 9n/2n/early 8n vs later 8n engines. I&T says the bore and stroke are same. Is is piston design or combustion chamber? If the difference is the chamber, then does my 52 8n have the same power as a 9n/2n, as the head was replaced many years ago with the "older design?" Is it also true, as I have been told, that quite a few later 8n's had head cracking problems that were solved with this retro?
